op 10-06-2025 09:43 PM
Hello,
I have a very annoying issue with my S23 Ultra.
when i try to edit long text in either the google or samsung calendar it will auto scroll to the bottom or some other random location in the text. when you click on a location to start editing the text the cursor will show up there and as soon as you start typing it scrolls down. The cursor stays in the correct position and is typing the text but I cannot see it because it scrolled that far. scrolling back up is possible but as soon as you type another character it scrolls again.
Some help is appreciated since it is driving me crazy
Thank you!
Opgelost! Ga naar oplossing.
op 12-06-2025 01:55 PM
Thank you for your feedback about this @Joeriii,
We appreciate it. When it happens again you can via the Samsung Members-app send in an error report to my colleagues of the R&D department. They can investigate this and when this can be resolved by an update this will be rolled out as soon as possible.
Feel free to let us know if submitting the report succeeded.
With kind regards,
Ajay
With kind regards,
Ajay
