No Sound problem with an FiiO external powered Q11 DAC&AMP on S22 Ultra
(Topic created on: 13-02-2024 10:39 AM)
Members_UfOOFwp
I get no sound when i connect my FiiO Q11 Usb DAC on my S22 Ultra (tried alot of cables even the small one bundled with my FiiO). The curious thing is that when i tried the same setup on my bro's A51 (android 13) everything works great. What could be the problem?Android 14 has a limitation on an external usb DAC (FiiO Q11 has an internal battery) or the problem is related to s22 ultra internal setting? I heard even on S23 Ultra there are people.complaining of similar issues.
I don't know if it matters or not, when i connect the DAC ,my s22 ultra gives this kinda of message: external large power usb connected. Cannot acces it because it needs external power supply.  Something similar, i dont have the device with me but this is the message.
Thank you,
Kat
Bucharest Romania
8 REPLIES 8
Obsydian
Samsung Members Star ★★
Hello - for what it is worth from a fellow AudioFool, forgot these add ons just get the Buds2 pro and a Premium Tidal or Qobuz account and enjoy. I used to use a Cyrus and still have an AQ Cobalt USB DAC.
Back to your question, what app are you using with the FiiO, as Android will always default to its internal DAC, is used to use USB Audio Player Pro.
That said no sound suugests another issue, not sure using a powered DAC into a S22U is a good idea.
2 Decades Samsung Ownership, Follow me on Instagram Obsydian_SMS
DAILY:  ZFold7, Watch Ultra, Fit3, Buds2 Pro, CL Ace 2, BT-W6, 20,000 PB, Smart Tags
FAMILY: ZFlip7, ZFlip6, Watch8, Tab S8 Ultra, Tab S7 Plus, Buds Pro2, Buds3 Pro
OFFICE: Book2 Pro i7, M70A 32”, Logitech K700, MX Ego, M720 Triathlon, Pop, Jabra Evolve2
AV/GAMING: QN95A 50” TV, Q900A, SW900s, 8 Series TV, LG OLED, M70A 43”, Dell Inspiron G5
APPLIANCES: Jet 75 Vacuum, MC32 Oven, American Fridge, 8 Series TV, LG OLED
SPARES: ZFold6, ZFlip5, ZFlip4, Buds1 Pro, Buds2 Pro, Book2 Pro i5, Level Speaker
MAINTAIN: iPhone 14, iPad Air4, iPad Mini4, iPad Pro1 12.9, Watch6
Members_UfOOFwp
I tried the FiiO Music app and also samsung's own music app.
Q11 is a powered dac&amp, i mean it has an internal battery.
The weird thing is that this setup works perfectly on a cheaper A51 and using only youtube app.
I think it has to do with another issue, or with android 14's or something related to s22 ultra system.
Obsydian
FiiO app or Samsung won't bypass the mobile internal DAC.
Also which are you sure what your using isnt a HEADPHONE AMP/DAC, if so you need to use the digital volume for that as it probably overrides the Samsung volume - but i still think without an app like USB Audio Player Pro your DAC is having no affect as the mobile DAC is the default.
Members_UfOOFwp
I tried also on youtube ,the same ,no sound. I also checked and turned down and up the fiio q11 's own volume *****, nothing.
From what i know, samsung s22 ultra dac applies only to its speakers and not to usb out?
Update: tried also on iphone 11 a few.moments ago, it works flawlessly. So far, only my phone doesnt work s22 ultra, the A51 and iphone 11 work great without any setting.
Members_NKV3LEs
Did you find a solution to your problem? I am having the same issue on s22 with my Oppo external amplifier/dac.
Members_W8QebXc
You must choose UAC 1.0 (default is 2.0) in FiiO app :smiling-face:
Members_sLFsoTB
Solved my problem. Thankyou!
Members_rXaoByt
How??? I'm dying trying to make work my SMSL M500 Dac to my Galaxy A55. It just doesn't no matter the cable. Also i have others dac/amp portable and they don't work. That's a real shame.
