NFC battery drain
(Topic created on: 27-05-2022 08:33 AM)
dsss
Helping Hand
Is there a bug with NFC? whenever I turn it on battery drains soo badly but when it's turned of battery life excellent. Is it me or anyone else facing the issue?
3 REPLIES 3
Ventor
Samsung Members Star ★★
@dsss To solve it, try the following: access Applications, click on the area marked in the screenshot, activate Show system applications and look for the NFC app. Clear the cache and data in storage and check. Tell us if it has been solved. Greetings.
"The quieter you become-the more you are able to hear..."
Tourbillon De La Vie
Working fine. I have NFC on all the time. Using GPay
KevP79
Voyager
If you only use it for payments you can set up a Bixby routine to turn it on when needed and turn it off when finished, my setup is
Opening payment apps activate NFC
If:-
App opened (Google pay, Samsung Pay)
Then:-
NFC On
Now you can turn NFC off and the routine will activate it when needed.
Hope this helps.
