Sluiten
annuleren
Resultaten voor
Zoek in plaats daarvan naar
Bedoelde u:
Oorspronkelijke onderwerp:
Battery Automation menu - missing
(Onderwerp aangemaakt op: 23-11-2022 10:52 PM)
1458 Weergaven
CitrusSNL
Opties
S22ultra / updated software / Android 13 / One UI5 / Dual SIM.
The "Automation" menu, is NOT present on: Settings / Battery and device care / More options (the three vertical dots) / Automation.
I want to enable the "automatically restart periodically", but the "Automation" menu is missing.
What can I do? Alvast bedankt.
1 Oplossing
Geaccepteerde oplossingen
Oplossing
Neo001
Legend
Opties
Hi, It is now replaced with Auto optimisation. Once you turn it on, the phone will restart as and when required.
Settings > Battery and device care > Auto optimisation> Restart when needed
Bekijk de oplossing in de community in het oorspronkelijke bericht
4 Antwoorden
CitrusSNL
Opties
What can I do?
Alvast bedankt.
CitrusSNL
Opties
What can I do?
Alvast bedankt.
Oplossing
Neo001
Legend
Opties
MartijnK
Opties
When you go to Settings / Battery and device care / Automatic optimization you can activate this option 😉
Groeten,
Martijn
members-moderator-signature-unpk-aug23-800x200
