29-02-2020 05:54 PM in
Galaxy S10 SeriesThe low-battery sound is the generic default sound, which is just a little blip which I hardly ever notice. However, I can't change it, the setting is grayed out, and strangely it says it's the "Silent" one when I know it's not. I'm using the Galaxy S10 with Android 10 (on T-Mobile in the USA).
01-03-2020 05:58 AM in
Galaxy S10 Series
Can you confirm how you navigated to this setting in your phone and I'll check my phone for you then.
Daily Driver > Samsung Galaxy s²² Ultra 256Gb in Phantom Black.
I'm here to help.
01-03-2020 10:11 PM in
Galaxy S10 SeriesThis should help:
Press the volume rocker to show the volume level, click on the arrow pointing downwards, and reduce the sound of your "system" sound. The low battery noise is usually under system sound, as it is with the unlock noise.
02-03-2020 05:47 AM in
Galaxy S10 SeriesHi @Alpha07
Nope I'm not seeing that under the 'system sound ' volume control slider. 😞
I'm here to help.
02-03-2020 02:47 PM in
Galaxy S10 SeriesCan you confirm how you navigated to this setting in your phone and I'll check my phone for you then.
I got it by long-pressing the notification then Details.
I also found it by going to Settings > Notifications > See All > menu > Show system apps > System UI...
Notice there that Low Battery toggle is grayed out.
02-03-2020 02:49 PM in
Galaxy S10 Series
@Alpha07 wrote:Press the volume rocker to show the volume level, click on the arrow pointing downwards, and reduce the sound of your "system" sound. The low battery noise is usually under system sound, as it is with the unlock noise.
Pressing the volume rocker then the down-arrow shows a System volume bar but the only thing I can do there is move it up or down or disable/enable it...
But I'm not trying to change the volume, I'm trying to change the ringtone.
Turning up the system volume turns up everything that goes through it, making other tones too loud. So that's not the solution.
02-03-2020 04:15 PM in
Galaxy S10 Series
@sadasulo wrote:Can you confirm how you navigated to this setting in your phone and I'll check my phone for you then.
Thanks for the walkthrough and Yes mine is unable to be changed too.
Perhaps send this as feedback via the Samsung Members App !
I'm here to help.
02-03-2020 04:35 PM in
Galaxy S10 SeriesYou know the way when you change the volume of your device, a bar appears at the top of the screen with your volume level? At the right of that bar, there should be an arrow. Click on it, and it shows you sound, notifications, system, ringtone and bixby volumes. Turn your "system" volume down.
03-03-2020 03:34 AM in
Galaxy S10 Series09-03-2020 01:58 PM in
Galaxy S10 SeriesHi all,
Just confirming for you that the sound type for the 'Low Battery' notification can't be customised. (I tried it on my UK S10 too - and asked at our end.)
The developers have advised us that some important system sounds are non-customisable in order to avoid user confusion that'd result from changing the entire sound system, and that they have no plans to change this for that reason.
