16-09-2020 06:52 PM in
Galaxy Note20 SeriesFacing much problem in whatsapp and messenger call. Too much Background noise being picked up by my speaker of Note 20 Ultra which is bothering the person at the other end. Downloaded latest security patch, did several restarts and also a regular reset. No change. Things seem fine while talking via phone and Bluetooth headsets, but really bad in speaker, especially in the third party apps. So disappointed. Found many people facing similar problem in another forum. Please pick this issue Samsung and provide an immediate fix for this via an update. This is really sad.
28-02-2021 12:39 AM in
Galaxy Note20 SeriesBrilliant, this worked a treat. Only recently I bought a new case for the Note 20 ultra which has magnets for its casing, Then when speaking to someone on a call they can hear themselves echoing which was very annoying. This has been going on for 2 weeks. Checked everything I could for possible fixes, even removed the new protective casing. No luck still. Then I came across your fix, tried it as you had mentioned .It didn’t work at first , then I restarted the phone. Hey presto it worked a treat. Thanks
24-07-2021 07:50 PM in
Galaxy Note20 SeriesSame issue here
Hope samsung is aware of this
05-10-2021 01:21 AM in
Galaxy Note20 Seriesthis worked well for one day and after that the same noise .. do you still have the issue ....
05-10-2021 01:23 PM in
Galaxy Note20 SeriesSame here, we have two note 20 's both have the same issues. As u mentioned one day it was fine after that the same noise issue when I use speaker.
06-10-2021 06:42 PM in
Galaxy Note20 SeriesUGH!!! I'm having this problem on regular phone calls even. This is a brand new phone I just got it yesterday. Not happy at all. Going to return it if this continues.
28-02-2022 05:07 PM in
Galaxy Note20 Serieswhat is the solution ?
05-10-2022 04:39 AM - last edited 05-10-2022 04:45 AM ) in
Galaxy Note20 Seriesfacing same issue in the end of 2022 with many BT device
- some 2-3 BT Chinese cheap earphones
- SONY XB700
becoming same noise
but all of that I try to used with many Phones (incl. Apple phone) , it's very clear sound even the cheap one
08-10-2022 06:23 PM in
Galaxy Note20 SeriesSame issue here. If Samsung does not fix this soon, I will have to change brands. Seems like they have been ignoring this for YEARS. With a flagship phone!
