29-12-2020 07:48 PM in
Galaxy Note20 SeriesBattery drain has been at least 30-40% higher after updating to one ui 3. Anybody else having this issue and any known fix?
- Also for some reason I'm not able to access wipe cache partition menu anymore either. Switch off phone, hold volume up and bixby button till logo comes. But phone just starts normally. Before update it worked.
29-12-2020 07:57 PM in
You may need to insert your headphones or hook upto a computer with your data cable to get to this menu on the phone.
Daily Driver > Samsung Galaxy s²² Ultra 256Gb in Phantom Black.
I have no affiliation with Samsung.
29-12-2020 08:35 PM in
Galaxy Note20 SeriesAttaching USB headphones helped to get the wipe cache partition menu to appear, thanks!
29-12-2020 08:37 PM in
Galaxy Note20 SeriesWelcome @ruuvvi
30-12-2020 12:34 AM in
Galaxy Note20 Series30-12-2020 12:37 AM - last edited 30-12-2020 12:37 AM ) in
Galaxy Note20 Series30-12-2020 06:43 AM in
Galaxy Note20 SeriesI just attached my original Samsung USB in ear headphones to phone, switched phone off, press and hold volume up + power/bixby buttons till Android logo came.
30-12-2020 06:48 AM in
Galaxy Note20 Series@Michael2103 can you instead hook upto a computers USB port. No software is needed etc as it's just the fact of hooking it up if the headphones option isn't working.
Galaxy Note20 Series30-12-2020 11:47 AM in
