Help :S Pen disconnected in Note 20 Ultra 5G
(Topic created on: 10-03-2023 02:13 PM)
KindMahmoud
My S pen suddenly stoppeed connecting and all air action not working now.
I reset it several times and nothing change
All sensors feeling the pen input and output and screen touch
I can't find reason or solution
2 REPLIES 2
BandOfBrothers
Hi @KindMahmoud
You could try > Clear Cache Files from the phone's System Partition Section  > https://www.samsung.com/uk/support/mobile-devices/how-do-i-clear-the-cache-on-my-device/ You may need to insert your earphones or hook upto a powered On Laptop to access the Clear Partition Section. This may help with lag or stutters as this clears the phone of old/unused or broken cache files.There is also a Repair Apps option in the Menu System too.
And as a last resort back up and Factory Reset.
If you can perhaps try another official Samsung sPen.
A Samsung Service Centre can assess your phone and sPen.
If I can be of any further help then please don't hesitate. Take care.  😎
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
KindMahmoud
Thanks....i will try that
