MORE UI7 Issues - Battery Drain
(Topic created on: 05-07-2025 09:50 AM)
IanJamesSeale
Good grief.  You really messed it up this time with this one.
Along with everything else that I've already reported, like others, I am noticing a significant change in battery drain since the upgrade to UI7.
Please fix this.
8 REPLIES 8
TympanicFir8748
They need to at least upgrade their battery saver at some point. This is so annoying.
TheRoyalPenguin
Voyager
That's normal after an update. The battery is recalibrating, and it will go back to normal soon. Samsung can't fix recalibration, and trying to rush is bad for your device.
Piper123
Samsung Members Star ★★
First, turn off Auto Blocker then follow these instructions EXACTLY as written
Using the Samsung Phone App (not the Google one)
Dial *#9900# then scroll down to battery stats reset. Click then restart your phone.
Turn Auto Blocker back on
Restart device
Wait 14 days for battery optimisation to complete.
Credits to @Moiramon and @lminvti for this information from previous threads
I am not employed by Samsung nor do I receive any remuneration as a Samsung Members Star.
My device is an S25 Ultra.
RevengeOneUI
Voyager
IanJamesSeale
Thank you.
I've downloaded it, and run all the tools.
People are also saying that it takes a while for the Battery to settle in with the new UI, but I'm not so sure.
We'll see how it goes.
RevengeOneUI
Voyager
Look at the comments on that thread for an explanation of what it does.
Members_TG7MsdF
Samsung
finn11
I just need a new phone mine wont turn on even if i put it on the charger theres a flashing like but i still wont turn onnnn
