AVG Battery Drain
(Topic created on: 29-11-2020 08:05 PM)
Ayajul
Hey,
Not sure why, but AVG Antivirus is draining so much battery. Anyone else having this issue?
4 REPLIES 4
Jason13v8
Pioneer
no I don't use it because there's enough security in S10 plus it will use battery do whats the point?. stop using it and it won't drain your battery or put it to deepsleep
Djraz
Pioneer
extra antivirus are nothing more safe.special.on phones!!... use samsung default one! are fully.no need licence and always support by samy.so on the new smartphone all this 3d app works but use a lot of battery between widget background process etc...
Jaybee360
Voyager
remove it. it's really not needed
MartynaK
Beta Moderator
Beta Moderator
@Ayajul,
In this case, I would recommend you to reinstall the application or just remove it if it's no longer needed. You can also report the issue via the Members application, but please do not forget to attach log files when you notice the issue 😉.
