Audio problems
(Topic created on: 13-11-2021 08:46 PM)
Graykenhill
Pathfinder
When using Spotify and galaxy buds sound cuts out frequently into the tune
1 REPLY 1
MartynaK
Beta Moderator
Beta Moderator
@Graykenhill,
It is possible that Spotify app is still not fully compatible with the One UI 4. Anyway, you can try to clear cache of the Spotify app (or reinstall it if necessary). Also check if any application updates are available.
If that won't help, report the problem via the Samsung Members app, right after it occurs :hand-with-index-and-middle-fingers-crossed:.
