Comparative memory speed between S23 256GB and S25 512GB oneui 7 vs oneui 8 beta
(Topic created on: 01-06-2025 05:35 PM)
marco_5
Pioneer
the s25 has a problem with random memories my s23 256gb is much faster , my s25 512gb is very slow the problem is surely solvable by working on the kernel
s25 512gb oneui 8 beta 1
the difference is obvious
s25 512gb oneui 7 march update
6 REPLIES 6
arianwen27
Samsung Members Star ★
Did this happen after installing the beta? Not sure how this relates to one ui 8.
Plus bigger number better isn't really a good way of measuring things. The s25 is way faster than the s23 in every task. One test might have a higher number on the s23, but actual usage has the s25 miles faster
marco_5
Pioneer
With the March update s25 512GB went very fast in memory, I have the screen now I edit the post
marco_5
Pioneer
Check the last screen I put on I would say there's a problem
AnnaMaz
Beta Moderator
Beta Moderator
Hello @marco_5,
Your input is valued! Kindly send an error report through the Samsung Members app to assist in identifying and resolving the issue.
marco_5
Pioneer
s25 512gb beta 2 ZYF3 same problem of beta 1 ZYER the memories are slow compared to the oneui 7 with march patch1749756621867.jpg
marco_5
Pioneer
the problem has not been solved and I have made many reports with the screenshots as well
