Battery drain
(Topic created on: 15-10-2023 12:42 AM)
rij03
After updating to the latest One UI 6 Beta 6 version, my s23 ultra battery drains faster than earlier. Anyone feeling the same?? Any tips??
4 REPLIES 4
Stiobhan
Voyager
Let it settle, always seems to drain faster until it relearns your usage and routines
mattb
Pathfinder
I always find once I clear the cache partition it settles down.
MagdalenaPo
Beta Moderator
Beta Moderator
Hello @rij03
If you have observed a sudden drop in battery performance, I recommend that you perform a wipe cache partition.
You can do it through the Recovery Mode the following way:
1. Turn off your device
2. Connect your device to the PC/USB C headsets via USB (not to the charger)
3. Wait until the message that the device is being charged appears
4. Press and hold down the volume up and then power buttons and hold them until the device turns on
5. Recovery menu should appear
6. from there select "Wipe cache partition" (you can navigate using volume up/down buttons and confirm with a power button).
Have a great day!
spikey1
Navigator
Mine has gone from 1 day 6 hours, to 16 hours! Not happy
