Sluiten
annuleren
Resultaten voor
Zoek in plaats daarvan naar
Bedoelde u:
Oorspronkelijke onderwerp:
Galaxy book2 pro 360 won't power on and red led light doesn't turn off
(Onderwerp aangemaakt op: 13-09-2022 06:39 AM)
1534 Weergaven
SALSH
Opties
Hi,
I have a Samsung Galaxy book2 pro 360 for a couple of months and it's been working fine until yesterday when it suddenly can't power on and the red led light does not turn off even after a whole night of charging.
I've checked the adapter and it works on other devices. I've tried all other options i can find on the internet like pressing both power and volume down buttons simultaneously for 10 seconds but that did not work.
Anyone encountered the same issue and how did you fix it?
Cheers,
S.A.
4 Antwoorden
MartijnK
Opties
Hi @SALSH, good morning.
Thank you for reaching out. How is your Galaxy Book doing? I will ask my colleagues what the right procedure is and when I got a response for this, I will send you a message!
Kind regards,
Martijn
members-moderator-signature-unpk-aug23-800x200
MartijnK
Opties
If you send me a DM (https://bit.ly/3BoC5B0) and I will fill in a form for a service request for your Galaxy Book.
Kind regards,
Martijn
SALSH
Opties
Hi Martijn
Unfortunately it's still the same. It doesn't power on and the red led light is still on.
Rgds,
Sherry
Jhon37
Pioneer
Opties
Ik heb het zelfde probleem met mijn book2 pro 360
