op 15-01-2018 12:01 AM
Hello,
I just bought a Curved QLED Monitor 34 inch LC34F791WQU, and have a problem with the sound in the monitor.
I am using the display port from my PC and the video works, but I also have a 8-10 sec delay. I found that if I switch the monitor and restart it, it starts working but eventally after a whila it happens again. Can someone help me?
Regards
op 16-01-2018 02:06 PM
op 17-01-2018 12:31 AM
Hi JoeriS,
Im am using the standard cables coming with the monitor. I tried both the display port cable (with mini adptor included with the monitor) with my laptop from work ( a pretty modern Dell) and with the hdmi cable to my older laptop an Alienware M17 R1. So basically both through the display and HDMI 1 port, i get this problem. However i can always fix it if i turn the monitor off and on again....weird. I have the HDMI 1 set up to 1.2 version on the monitor. I have came across people with the same problem in the samsung forum in the US. Thats how i found out that turning it on and off, solves momentarily the issue. Maybe this can be solved with some firmware update...
Hope you can find a solution.
Regards,
op 17-01-2018 03:32 PM
