Equaliser Under Sound Quality and Effects
(Topic created on: 16-08-2023 10:58 PM)
JWindle92
I wanted to ask everyone's opinion on what their preferences are for the Equaliser that's found in Sound Quality and Effects under Sounds and Vibration in the settings.
Out of normal, pop, classic, jazz and rock, which does everyone prefer?
If you use the custom option, what would you recommend?
3 REPLIES 3
Joeeye
Legend
It's a personal preference option, why would you need someone to tell you theirs? It will typically come down to how good/bad your hearing is and the kind of sound that pleases you when listening.
To answer your post however, mine would be the default setting.
TechZilla
Samsung Members Star ★
I prefer normal personally
TechZilla - Samsung Members Star
weskerevil
Helping Hand
Mines on normal 👍
