Larger SD card help required
(Topic created on: 17-05-2021 09:22 PM)
funchef
Hi all
I have an S8.
Am having major issues with memory for pictures, video, spoken word recordings all of which due to my work.
My phone memory is full as is my memory card, so require some help in the follow situations, please.
Have removed a Very Large amount of photos, videos etc from my S8 onto my back up storage already, but still having amjor issues, no space left for photos or Apps
am down to just basic Apps now
Have bullet Pointed them as find it easier tahn waffling on.
Thanks in advanced
  • Want to upgrade to a 256GB sd card, what one is best and where to buy from?
  • How easy is it to transfer from excisting phone memory and excisting card on to new SD card.
  • Is there a transfer programme i can use froma surface pro laptop.
Thanks
Gary
3 REPLIES 3
APARMAR
Troubleshooter
https://www.amazon.co.uk/SanDisk-microSDXC-Memory-Adapter-Performance/dp/B08GY8NHF2/ref=sr_1_3?crid=...
This is the best SD card to get but it is £32.
Its very easy to transfer stuff from the phone to the SD card.
My best tip is to move all the stuff from your phone to your laptop and then insert your 256gb SD Card into the laptop and transfer all the stuff you just transferred to the laptop onto the SD Card.
funchef
Hi
Thanks for details, sound easy.
just the one question.
Where do i insert the SD card into my surface pro laptop?
there is a port above the UCB port, is that it?
Thanks. if you meaage back will pick up in morning as of to zzzzz
APARMAR
Troubleshooter
Send me a picture of the port above the USB C port and I will tell you.
