21-10-2017 05:52 PM
Has anybody else have a problem with step counter on there watch.For example a walked to work and it's 250 steps,then I look at the watch and it says 460 steps.Another example I sleep in my lorry get up start driving and after 4 hours of driving I stop for a break and watch says great workout 3250 steps when in fact I done about 8.I just think for 180£ the watch would be a bit more accurate
22-10-2017 04:53 PM
Hi @Dinotoovey I have the gear also and as it is quite sensitive I think yours is picking up your movements as your driving
You could have a look in your settings and look for workout detection and you can untick the boxes and see if that works
Also just before you are about to drive if you hold the bottom button for a couple of seconds you can go into power saving mode and that will still count your steps but disable other features and put your gear in grey scale
