20-02-2022 12:23 PM
I got my s21 FE 1 week ago. I have never had a phone before when the battery drain as fast like the s21 fe.
If you are lucky you get 2-3 hours screen on time. The biggest problem is that the battery draining very fast in idle. 10% in 1 hour when in not using the phone.
No matter if im connected to wifi or 4g(dont have 5g connection).
Always on display is off. Brightness on screen is low. Location services is off. I have all my apps in deep sleep mode when not using them. The only thing i do in the phone is browsing the web. No gaming, No video, No audio. I get 7 hours screen on time with my 4 year old oneplus 6t with the same type of daily use.
Anyone else expering bad battery time with s21 fe?
08-10-2022 06:30 PM
08-10-2022 07:58 PM
This is the costliest phone that I ever bought and have the worst battery life. My 3year old phone still lasts more with full on screen time than S21 FE in idle state. ***** this phone.
09-10-2022 12:25 PM
Never heard anyone before talking about this option.
I've turned it on hopefully it does something to the horrible battery drainage
13-11-2022 11:48 AM
Same Issue .. like .. i never see such drain my 12 years of smart phone usage... no bad app. just brand new bought .. disabled all possible thingk .. 120 hz brightness sync, fingerprint display.. you name it.. i have disabled and have only few apps.. but if i view fb for 10 min 5%+- gone.. and HEAT ISSUE MY GOD.. LIKE A FIRE BALL ALWAYS... found no way to keep coool.. both issues are at worst stage
03-01-2023 06:27 PM
Same issue here
I'm Losing 1% every 4min when normally use
04-01-2023 05:55 AM
Same with me .. its means i should not go for warranty as its a model issue or all the batteries used in this model are like this.. have to live with it or throw it out and buy a new PROBLEM means new samsung. but the question is which one or go for xiaomi 12 t pro
14-09-2023 08:01 PM
I am having excat same issue i have been to samsung service center 4 times onece they sai they replaced battery once they said they replace motherboard and what not but issue is not fixed
14-09-2023 11:14 PM
Hi dear.. No way... Simple replace this phone..
01-02-2024 03:28 PM
Is your issue resolved? I am also facing same, I checked in Samsung service center, they changes to new battery still same issue there, and check in local center there is no issue with board as well.
02-02-2024 11:40 AM
Yes it gets a lot better with time and with updates, the battery lasts me a day.
