Watch5 pro pin lock
(Topic created on: 09-09-2022 07:00 PM)
nik_singh
Been having an issue with the pin lock where sometimes when I lift my wrist to check the time or read a notification it asks for the pin.
Tried turning it off but then it completely removes samsung pay then when I set it up again it asks for pin or pattern lock to be enabled to continue.
Anyone else experienced this??
6 REPLIES 6
Neo001
Legend
Hi,
Are you wearing it too loose? If the sensors cannot detect that you are wearing the watch, it will ask you for a pin.
Have you tried resetting the watch?
nik_singh
Well I think its on tight, I can slide a quarter of my index finger between the strap and my wrist without much force. Yeah I've done a reset but it just happens again. Very strange.
Lingard87
Pathfinder
This is annoying as hell. I don't know why they didn't set the pin to only request when using Samsung Pay like they did with tizen
IndiW
Hotshot
I think it's a malfunction, I had 5 pro (returned as Blood O2 was not working and waiting for a replacement) I did set up pin, did running and other daily tasks but never asked for pin, only when I removed the watch
If you have hair around your wrist, try shaving 😂😂
nik_singh
😆 could abit of wrist hair really be the problem???
IndiW
Hotshot
Ha 😂😂... Wrong hair... at the wrong place.. This is serious... 😂...
