Watch 6 47mm charging problems
(Topic created on: 14-09-2023 02:45 PM)
xn1ckyx
Hi
Does anyone else have the same problems?
1 Watch turn off when on charge and stop charging
2 when on wrist and you don't enter your pin the battery drain fast.
I've reset the watch about 3 times now still have the problems from a 9 days old watch. Very disappointed had no problems on my watch 4
6 REPLIES 6
AshS23ultra
Maestro
I can answer number 2 which is because you haven't put the pin in I'm guessing the watch is trying to establish whether it's on your wrist or not. I find if I wear mine 5 pro without putting the pin in the led underneith goes wild. As for number 1 my only possible answer is it could be over heating? Probably contact customer services on that 1st one
Ferenc75
Helping Hand
Did you tried the clear cache recovery process on your watch?
lmmartinsn
Pioneer
How you do that?
xn1ckyx
Reset 3 times and clear cache everytime
Ferenc75
Helping Hand
xn1ckyx
Hi everyone
Finally sorted out the watch by replacing it with a few problems!!
When back to the samsung store with the 14 days old watch. The sales person told me I had to have a technical look at it 1st and if there anyone problems they will send it off to repair which takes upto 2 weeks. I said wait I've only brought it 14 days old ago. Can't you just replace with another one. Sale person said no. Whats that bullShxxt about. Finally ask to see a manager show them the problems than said OK I can see the problems and replaced it for me thanks.
SAMSUNG you must train your staff in store better.
