Watch 5 Pro battery issues
(Topic created on: 24-01-2024 02:41 AM)
PaulRomeo
So over the last 4 days my battery life has dropped from over 28 hours on a charge to being lucky if I get 16 hours, no changes to settings, no new apps installed, no changes at all to be honest. Any idea what could be causing this?
9 REPLIES 9
GoanGeek
Samsung Members Star ★
Sync issues?
PaulRomeo
What do you mean?
GoanGeek
Like if the watch is trying to sync to contacts or messages or something and not able to connect and it keeps trying and trying and hence draining the battery.
You could try turning both your phone and watch off and o. And see if it helps.
PaulRomeo
Nah no sync issues either, tried turning both off and on again made no difference. Really annoying as I was extremely happy with the battery life before this happened 😒
GoanGeek
Maybe someone using the watch will reply.
Any app updates for phone or watch?
PaulRomeo
Not for the watch, but now that I think about it there was a software update for my phone last week, not sure if that could cause any issues though 🤔
GoanGeek
Could be a possibility as well.
Samsung is apparently gonna push a patch for one ui 6 in February to sort out quite a few issues and errors people have been facing.
Elvisthefenboy
I've had the same issue so have tried a factory reset on the watch and now it will not reconnect. Just about to throw it out of the window in frustration. I'll let you know if it bounces.
PaulRomeo
Yeah I done a factory reset a while back when i was having network problems and now my esim doesn't work and vodafone aren't willing to help, and the nearest Samsung approved retailer is like 70 miles away from me
