Watch 4 battery drain
(Topic created on: 22-12-2022 04:17 AM)
Mattmam
Wearables
Is anyone having massive battery drain with the Samsung watch 4 classic my watch battery isn't lasting the days . I am averaging about 6 hours from a full charge. is anyone having that same issue?
6 REPLIES 6
Neo001
Black Belt
Wearables
Hi, I have observed that after the update, the battery drains quickly, but after 1-2 recharges, it goes back to normal again. I get little under 2 days on my GW4 Classic. Have you checked what's draining the battery?
Mattmam
Wearables
Yes I have checked. I've changed watch faces. The issue remains. I will just reset it back to factory settings and see.
thanks
Fizaan
Navigator
Wearables
Hi my galaxy watch 4 needs 1 recharge during the day to stay on the whole day so normally use power saving mode to keep my watch on for about 3 days 🙂
Mattmam
Wearables
I reset it back to factory settings and it's OK now 👌
Ashwh
Wearables
Mines really bad since the update. Its lasting less than a day and I'm actually using less features than I normally would
Mattmam
Wearables
Try factory resetting it
