01-07-2022 04:56 PM in
WearablesI had resolved the issue long ago by turning off constant heart monitoring, but just the other day I nearly got burned again. I fixed it by going to my Wear App, selected apps and opened reach one to see which we're using memory, and either disabled or uninstalled. This solved my problem, again, after a recent update. Samsung is ignoring the issue and will continue to add new 'featured apps.' so you will need to regularly review app usage whenever your watch starts to feel hot. Hope that helps!
01-07-2022 06:40 PM in
Wearables01-07-2022 06:42 PM in
Wearables01-07-2022 07:23 PM in
WearablesHi @Charlie306 ,
that shouldn't be happening. Have you got the watch examined by one of our engineers? If not, we would suggest contacting our Support Team to get this looked at: https://www.samsung.com/uk/support/contact/
02-07-2022 07:16 AM in
Wearables22-07-2022 05:20 PM in
WearablesThanks for your help. ❤️ 🌹 Have a great day.
22-07-2022 06:10 PM in
WearablesI got it for heart monitor as it advertised, it shouldn't overheat,if so they should be pulled off shelf.
Sorry you got burned. 🕊️
