26-12-2016 10:42 PM
Hi
Has anyone been having migraines following sessions on the Gear VR?
With thanks
Solved! Go to Solution.
06-01-2017 03:55 PM
Hello and welcome, Bertie36!
We know it's hard to put down, but we recommend taking regular breaks when using the VR Headset. Also, be sure to adjust the focus wheel at the top of the Gear VR as this will help to reduce any eye strain you might be facing.
We hope this helps. :smileyhappy:
06-01-2017 03:55 PM
28-08-2018 03:25 AM
Could it be possible that the headset is a bit too tight around your temple area? Also the behind the head strap may be constricting blood flow.
Consider loosening the strap.
Also be sure to stand up and bend your legs occassionally to get blood circulating in the body overall.
