Tips regarding battery needed :(
(Topic created on: 04-08-2022 06:18 PM)
imstef
Pioneer
Hey! I got myself the Galaxy Watch 4 Classic LTE, but I am sad to see that my battery is draining very fast. These are my current settings:
  • Sound: On
  • Wi-Fi: Off
  • Cellular Data: On
  • Bluetooth: On
  • NFC: Off
  • BPM: every 10 minutes
  • Stress: Always on
  • Power saving mode: off (I want to try to use this only in emergencies)
  • For night:
    • Bedtime mode: Sleep only
    • Oxigen during sleep: On
    • Snore detection: On
  • Google Assistant: Deactivated
  • Bixby settings: Voice Weak-up is off
Apps installed: (media attached)
Screenshot_20220804_200133_sysui.pngScreenshot_20220804_200137_sysui.pngScreenshot_20220804_200143_sysui.pngScreenshot_20220804_200148_sysui.pngScreenshot_20220804_200154_sysui.pngScreenshot_20220804_200157_sysui.pngScreenshot_20220804_200122_sysui.pngScreenshot_20220804_200125_sysui.png
PS: If you can recommend me anything, but not to modify my settings would be great, because I had the Emoji AR face for 5 hours and from 70% it went straight to 0%.
Any tip, even if it's little, it will help me. Thank you!
19 REPLIES 19
IndiW
Hotshot
If the watch is very new, I think it will take 2 weeks or so to settle down
If you continue with current arrangements, how many times do you have to charge within a 24hrs period
imstef
Pioneer
Hey! So, the watch has at least 5 weeks, and I usually charge it before I go to bed and after I wake up, but this happens when I use a static watch face. For animated ones, the watch doesn't last 16 hours.
Beckyb
I charge mine every 2 days. Sometimes it will start draining very quickly and I saw on here to clear the cache.
I looked up a video on youtube how to do it and it was very easy to do and sorts it out again for a few months then I will have to do it again.
I cant understand how yours lasts less then a day! Do you use it for music etc? I know the GPS uses a lot of battery which I dont use that often but mine always lasts 2 days.
Maybe there is something wrong with yours if you need to charge it every 12 - 16 hours!
imstef
Pioneer
Hey! So, I don't use music, I just use it the basic functions of a watch. I have to ask you: what watch face do you use?
Beckyb
Hi, I use just a static one. It has HR on it which is on constant, weather, battery, steps and the time. Its quite a plain one.
I dont use music but have the wifi, bluetooth and NFC on all the time. I use it for messages occasionally and notifications etc. Stress is on all the time.
I charge mine at night before bed and then it will last 48 hrs and I will charge it again at bed time. If I use GPS a lot (when out on a long walk or bike ride) I may need to charge it a little before bed so it may last 40 hrs instead of 48 but its usually very good.
When I need to clear the cache I know about it. I will charge it at night and by the next morning it will be at 15%, then I know somethings wrong. Once Ive cleared it it goes back to normal.
You really should try this as it sorted mine out great, I got mine September 2021 and its still going great. If I had to charge it every 16 hrs id have sent it back!
imstef
Pioneer
Hi! So you mean that I should wipe the cache partition on my watch?
Beckyb
Yeah, do you want me to post a link to the youtube video I watched and did.
Its the only thing I can think of. I searched here when my battery was going flat in 12 hours and it was the only thing that worked. It usually happens to me after an update. I dont know if it leaves stuff there (I dont know nearly enough about it) after an update. I did report it to them but never heard back.
I clear that each time and it back to normal lasting 2 days. There should be plenty of other threads on it as thats how I found out about it on here.
imstef
Pioneer
Yes, if you could post a link to the video it would be awesome! Thanks in advance :smiling-face:
Anonymous User
Not applicable
Replace the battery as a last resort
