Samsung watch 4 bluethoot - earphones call do not work
(Topic created on: 21-10-2021 03:50 AM)
castanedasergio
Has anyone been able to make or receive calls on their headphones from the samsung watch 4 bluethoot? I have tried with panasonic, xiaomi and samsung headphones and the calls can only be heard on the speaker of the watch.
2 REPLIES 2
Potshot2k4
Pathfinder
Your headphones are more than likely connected to your phone rather than your watch. You need to pair headphones to your watch then when you answer using the watch if they are connected you will be able to call and listen thru them.
AndrewL
@castanedasergio: Can you confirm, as per the post above, that you have connected your headset to the watch itself via Settings > Connections > Bluetooth?
