Go to solution Solved
Samsung Gear - Installation failed - error code: -110
(Topic created on: 24-02-2018 08:07 PM)
resteves
Hi,
Today i resetted my phone, and after installing everything i went to my Samsung Gear Fit2 Pro and clicked on connect to new phone, and when i try to connect to Samsung Gear application a get this error:
Installation failed !
Error Code: -110
Any ideas?
resteves
That didn't worked.
But i already found a workaround, for some reason is not prompting to install the gear plugin and the samsung accessory service, i installed them manually and now everything is ok.
2 REPLIES 2
BandOfBrothers
Try either clearing the Apps Cache and or clear the system file cache of the phone and try again.
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
resteves
That didn't worked.
