Samsung galaxy watch active 2, 44mm LTE, battery drain
(Topic created on: 01-11-2019 11:55 AM)
Knödel
Performed on clean system:
Wifi: off
NFC: off
BT: off
AOD: On
HR tracking: 10min setting
ALL activitiey tracking turned off
Bixby: off
LTE and mobile data over 4g/3g auto: on
The watch drains about 15% per hour. While doing: nothing. No text, no activate the screen. Nothing!
And the device could easily overheat over LTE
Straight from the charging (taking it off when at 100%) overheated the watch within minutes.
It has stopped charging while LTE is on - and overheated and prompted to shut down in order to cool down.
I have the possibility to send the unit for repair  but is that necessary if this is a software issue acknowledged by Samsung software team?
@samsung
Is there a fix coming out for this anytime soon or should we with lte units return our devices to store?
36 REPLIES 36
Nikobre
Same hear.....rode a bike for an hour ,strava was on and internet radio listening with my Bluetooth headphones and 3% battery left. Not exeptable and thinking of returning mine as well
denilsonms
I restored my watch and battery problem was solved.  I also deleted apps that I was not using. I hope it helps you.
moulsonp
Watch currently with Samsung for a third repair attempt. Zero hope for a fix but seems I have to jump these hoops before they will even contemplate a refund. Joke really.
moulsonp
Interesting.  Actually first report I've heard of someone fixing this. To be clear this is a decent battery life while on 4g connection right? Not just on bluetooth?
Countless full resets,  2 new watches and nothing but preloaded apps and the thing overhears, resets several times and then loses all power within 3-4hrs.
Aare
Hello, sharing the same bad experience with LTE, battery life is 3 hours with 4g on. 3 times in warranty, customer service keeps telling that its due to bad signal and use blootooth for connection with phone - my main the reason for the purchase was to connect it with e-sim and now they are telling its useless ? Really frustrating,  after the purchase you are on your own and stuck with an expencive watch where main function for me does not work.
jordanms
I have the same issue, on 4g battery last 3h max. Add my watch is on guarantee, I'll try to return it.
It's the second time Samsung let me down, first time was with the robot vacuum cleaner. If continue like that, I'll not buy Samsung anymore.
Maitai
Same issue here, just got it for Christmas turned on lte to use at work so not to miss calls. Wanted to check my steps and it's dead within 1hr of turning on lte. With Bluetooth it works all day.  I really want to love it but this gift is a dud.
