Samsung earbuds pro
(Topic created on: 13-05-2022 05:38 PM)
Rends
Wearables
Hi everyone,
Just a quick rant... only because it has happened to me but luckily end with a happy ending .....BUT
Why doesn't the earbuds pro have a tracker built in like the smart tags ( that I have and I think are fantastic !! ) or something similar...
I lost my earbuds abd went to my apps smart thing find and galaxy wearable app unfortunately no joy unless they are loose out of the open case .... It did show last place hat I used them but that was out of date as I checked my friends house , they wouldn't ring or anything .... waste of time having that function ...
Yes if you drop them the ring is great but 98 time out of 100 they will be in a closed earbud box ....
Just saying put a tracker in the charging case .. to me that's commonsense especially for the cost of earbuds compared to a smartbtag ...
Rant over
Rends ....
6 REPLIES 6
Blessed4life
Hotshot
Wearables
Good idea, makes sense.
Robot_
Troubleshooter
Wearables
I have attached a smartag+ on them for just that reason
Rends
Wearables
Abit Bulky for me but still a good idea ...thank you
Robot_
Troubleshooter
Wearables
I agree but what you going to do? I got spigen buds pro case and attached a smart tag+
Only annoying thing is the smart tag+ battery life sucks, last about 6 months
GoanGeek
Big Cheese
Wearables
You can Change the battery.
Also depends how much you keep using it.
Robot_
Troubleshooter
Wearables
I know I can change the battery, but still annoying
I just have it attached to my ear buds, I don't use it for anything except that, don't use the button
