Replacement rubber tips for galaxy buds pro
(Topic created on: 16-06-2022 09:44 AM)
PClout94
Hi, my dog managed to steal one of my galaxy buds and destroyed the rubber tip. Where could i purchase a set of standard tips again for my galaxy buds as I like the way how these tips feel?
Thanks :smiling-face:
2 REPLIES 2
StuartR
Troubleshooter
You could try reaching out to samsung they may sell them separately or if you have a Samsung experience store near you ask them I'm sure they'd have some laid about.
You can also get 3rd party replacement ones on ebay and amazon..
Richmar83
Helping Hand
Best bet and cheapest would probably be Ebay. I replaced the tips on my Buds Pro with memory foam ones which are alot better comfort for me and noise cancelling. Won't go back to the OEM rubber ones
