My Gear Fit2
(Topic created on: 17-09-2017 08:50 PM)
PMcG
It has started discharging in 3-5 hours without any excercise tracking on regular usage.  Needs replacing?
2 REPLIES 2
BandOfBrothers
Samsung Members Star ★★
Is there a Hard Reset / reset option which may help ?
A Samsung Experience Store or Samsung Service Location could run a diagnostic on the device.
Daily Driver > Samsung Galaxy s²⁴ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
AntS
Hi @PMcG.
Might be worth a quick check that all of the software (including the Gear Manager app) is up to date, along with turning Wi-Fi off if you're not using it. Other power-saving tips are: decreasing the screen brightness; deactivating the Watch Always On feature; and customising the Notification settings to limit them.
There's some guidance on backing up (here) and resetting (here) a Gear Fit2 on the US Samsung site if you need to follow through on the first step of BandOfBrothers' suggestion.
