Is Samsung Trio charger compatible with Watch 5 Pro?
(Topic created on: 19-09-2022 03:22 PM)
MichaelM4
Hello, I have a Samsung Trio charger (EP-P6300TBEGGB) I used with Watch 4.
Is it compatible with Watch 5 Pro?
It seems that watch 5 on Trio heats more than on its off-the-box charger.
Thanks!
Samsung-Wireless-Charger-Trio-EP-P6300-1599047085-0-0-1500x1000
8 REPLIES 8
Reylob
Big Cheese
The Watch 5 Pro cannot be charge on those flat chargers unless you remove the strap. It is the same with the Wireless PowerShare. One has to remove the strap for it to seat flat on the phone to take advantage of that feature.
There is an article on https://www.sammobile.com/news/galaxy-watch-5-pro-strap-design-wireless-charging-nuisance/
Reylob
Big Cheese
MichaelM4
Thanks, this isn't the strap issue, I tried with Samsung leather hybrid strap I have from Watch 4.
Germán
Exelente aporte.....
blockhead
Yes turn your watch inside out cover screen with hand so straps are pointing up it is designed that easy so you don't have to undo strap
blockhead
Yes it can turn your watch inside out so straps are pointing up place on charger and reverse it when finished
Mredodos
the problem is that forcing the plastic in the long run will break it's not designed to do those flexes you can see from the design, detaching the strap takes a little longer and again it's not something designed to disconnect it all the time.
really bad design.
