Is my Gear S3 dead? Continual charging.......
(Topic created on: 19-10-2018 07:50 PM)
kriptikchicken
Pioneer
Well last night we had a power cut and althogh it is a pain in the ass getting my S9+ back fighting fit again. My Gear S3 is a different kettle of fish.
The problem is, it just keeps charging on the splash screen you get when you first turn it on. To add insult to injury, you just cant turn it off..... When you try it momentarily, says 'Rebooting....' then it goes back back to charging. Now I have tried bleeding the power out of it (which works), but the second you put it on charge again, it is back to the old splash screen again....
I’m at a loss, are there any button combinations I can do to break the cycle, I know there are only 2!
1 REPLY 1
BandOfBrothers
Samsung Members Star ★★
Will it allow you to get into the settings to reset it in there ?
If not and your still experiencing these problems then a Samsung Experience Store or Samsung Service Centre will be able to help you.
Daily Driver > Samsung Galaxy s²³ Ultra 512Gb in Phantom Black.
I'm here to help. " This is the way. "
