Incoming calls
(Topic created on: 23-11-2022 04:49 PM)
SW2
Pathfinder
When answering calls via my watch most of my incoming calls go through to the phone and I can't pull them back without going to the phone? Any ideas on how to fix this?
Also when phone connected to watch and the car Bluetooth the car doesn't ring? I have to disconnect the watch from the phone for the car bluetooth to work. Is this happening to anyone else??
5 REPLIES 5
robd1
Voyager
Hello @SW2 my pro 5 LTE worked fine until latest watch update. Had to wipe cache on watch before it worked again.
SW2
Pathfinder
Mine is the Bluetooth version. How do you wipe the cache?
robd1
Voyager
Hi @SW2 you're never going to be able to to use the watch in isolation from Bluetooth and I don't believe it has multi connection capability yet. There are many You Tube videos on wiping the cache on the watch.
SW2
Pathfinder
Thanks I'll look it up... but the phone should be able to connect to multiple devices... it used to on my s3 frontier... just doesn't with this watch 5 pro
SW2
Pathfinder
Samsung have fixed this issue now with the last update.
