Inaccuracies in body composition
(Topic created on: 14-06-2023 09:06 AM)
Danito
Hi members,
When I do a few measurements in a row to check body composition with my watch 5, I noted some differences in the percentage of lean/fat mass.
For example using always the same weight of 70 kg, at the same time 8:38 am of today, my fat percentage ranges from 11.4,%, 12% up to 12.7% and 12,%.
Obviously I was in the excat same position for all 5 measurements I had.
Any idea how this is so innacurate? Any improvement?
Thank you
4 REPLIES 4
Danito
Dannyboii
Navigator
That used to happen with my fitbit scale. Tbh I don't think anything could actually be accurate unless à surgeon was to cut the fat out and weigh it 😜
Dannyboii
Navigator
I'd take af ew readings and just go with the average really. They're pretty similar. My scale used to give some rediculously different readings
Danito
Thank you Danny!
This is what I am doing now.
I believe it is quite normal for a watch to be slightly inaccurate when measuring the body composition. Thank you fornyou answer 😊
