Help my stair counter has disappeared
(Topic created on: 11-04-2021 04:45 PM)
Suzy47
Since my last update my floor counter has disappeared.  Where can i get one to put on my watch . I know they are not accurate but i was challenging my daughter to see who could  get most in a day now hers is working but mine is absent .
6 REPLIES 6
Fiona26
Samsung Members Star ★★
If you go into galaxy Wear app for your watch. Go into widgets and add it back to your watch from there. Or you can add widgets using your watch. Press and hold until you can scroll through them.
Suzy47
Tried but its not on there anymore
Henry3585
Uninstall the app and re install it
Suzy47
Wont that remove all my data as im doing challenges and dont want to loose info
Fiona26
Back up your data first, hopefully once you restore it should be all there. I hope. Can't guarantee challenges will be.
Suzy47
Thank you . Will try
