Go to solution Solved
Gear Sport for use in salt water
(Topic created on: 30-06-2018 10:24 AM)
Joe7082
Hi
I am interested in purchasing the Gear Sport. I have read that it is fine to you in Salt water. What is the longevity of the device when exposed to salt water regularly with proper rinsing in fresh water. I work in an Aquarium and I dive in the larger tanks (4-5 meters) would this affect the device?
Thank you
Go to solution
10 REPLIES 10
chrisbarett
Hey, man. You will be a bit shocked, but I'll open you one secret. Long story short, you should know, that all around us, I'm talking about the innovations, are taken from the nature (ability to swim under water, to fly, to protect gadgets from the water and others), so majority of the whatch have the protection, like the worms. If you don't believe me, then you can read the ARCREEF's article about these worms and make sure about my words. Soooo, the answer for your question is "YES". Good luck, dude.
