20-06-2018 11:26 AM
Hello,
Yesterday, I noticed my gear S3 (3.0.0.2) activated the Outdoor mode, during which I could not adjust the brightness. First time I saw this...
What triggers "outdoor mode" ? (measured brightness? gps?)
Can it be enabled/disabled manually?
Can one set specific settings for outdoor mode?
Thanks!
Jörg
Solved! Go to Solution.
20-06-2018 12:10 PM
Welcome to the Community!
20-06-2018 12:10 PM
20-06-2018 12:18 PM
Thanks!
I noticed the display was quite bright and I tried to adjust it. I was a bit surprised when it popped up as I had never read about this feature. It all worked as it should (I could adjust the brightness again later), just got curious. 🙂
20-09-2018 07:43 PM
Q: My Galaxy watch AOD in "outdoor mode" is dark, unreadable outdoors. Is this the way it's supposed to work? Doesn't make any sense. I cannot find any info relating to this in any Samsung User manuals. I've set the display as bright as it can go and Auto low brightness to both "on" and "off" without any noticeable effect on outdoor readability.
05-10-2018 06:21 PM
This happened today. Couldn't read the watch it was so dark. Worse feature so far for me on the GW.
22-10-2018 02:36 AM
I have the same problem. Outdoors in bright sunlight it automatically dims the screen so you can't see it. I found a solution. Go indoors, which switches off the ourdoors mode, turn the brightness up to full, then return outdoors. It goes back to outdoors mode but with full brightness. I look forward to Samsung bringing out an update that allows you to switch off outdoor mode - hopefully Samsung is listening!
29-11-2018 09:19 AM - last edited 29-11-2018 09:32 AM
Same defect (for me it is one) with my Gear S2: Activated AOD and since Outdoor Modus Update: no recognizable Display outdoor! You have to tap on the diaplay to get ist visible - No influence by "automatic brightness" activated or not.
Senseless AOD....
Any reactions known from Samsung?
Is it possible to roll back gear-software-updade? => To get rid of this outdoor modus!
A visible Display at a watch is a key-function! It is understandable to work to improve the battery-life, it is competion argument.
Who needs a porsche with a tow-bar but no wheels...
;o)
15-12-2018 06:31 PM
I am having this same issue, is there any fix????
17-12-2018 03:03 PM
i didin´t hear of any... ;o(
So - I put my gear s2 back to factory condition and after pairing I deactivated the automatical gear-update so the "sensless one" doesn`t come back to my gaer - now AOD mode works fine, but addiional functions sorced with updates -> I don`t have..
30-04-2020 09:07 PM
