Gear s3 frontier
(Topic created on: 17-06-2019 04:16 PM)
Tommy19
Does anyone have any idea how to clean the watch I'm to nervous to do anything to it.
AndrewL
@Tommy19: In the user manual it states that you should "rinse it with clean water and dry it thoroughly with a clean, soft cloth." It also says "Do not expose the device to water moving with force," so I would avoid running it under a tap, for instance, and instead run some water into the sink and rinse it in that manner. I hope this helps.
2 REPLIES 2
AndrewL
Tommy19
Alright thanks for the help
