28-05-2018 02:58 PM in
WearablesHi
I have recently updated my Gear S3 Frontier to Tizen 3.0.0.2
On Tizen 3.0.0.1, I had a battery life of approx 3 days - after updating to Tizen 3.0.0.2, I have a battery life of max 1,5 day.
1. Do other users experience the same?
2. Does anyone have an idea of what could suddenly drain my battery so quickly?
Solved! Go to Solution.
17-10-2018 07:39 AM in
WearablesThis issue is happening for me too, I can see there's a large gap since this initially occured, some months even. C'mon Samsung help us out!
17-10-2018 07:45 AM in
WearablesHi ,
have the same model and also the same 3.0.0.2 update , and after 7 days i started to drain battery....
17-10-2018 09:34 AM in
Wearables Looks like i just joined the club.
Can't check the versions at present ... the battery has run out.
17-10-2018 01:56 PM in
WearablesCouldn't have said it better myself. I did a hard reset about a month ago and it solved the problem; the battery started draining like a sieve this week, did a hard reset and it hasn't done anything to resolve the issue, just like everyone else has posted. I'm really beginning to doubt that anyone at Samsung even reads these posts and realizes how frustrated their customers are.
17-10-2018 02:55 PM in
WearablesThe main reason of this issue is the app and 3rd party watch faces. Please just reset your watch and make sure fully carged. Now use normally without any third party application. I hope your problem will be solved.
Thanks
17-10-2018 03:05 PM in
WearablesNo, it isn't - I don't use any third party apps and still have the default watch face
17-10-2018 04:08 PM in
WearablesSOLUTION: turn off "dynamic workout" detection in the watch settings. It worked for me.
17-10-2018 04:41 PM in
WearablesThis is a new issue not related to watch faces. My battery in the last couple of days has gone from 100% to 0 in around 12 hours or less. No new watch faces or updates in that time though I have noticed higher data usage on the Samsung accessory service app, 160mb in a 6 hour period in the background.
17-10-2018 05:04 PM in
WearablesI'm not finding that in settings, how do you turn it off?
17-10-2018 05:11 PM in
Wearables
