28-05-2018 03:58 PM in
WearablesHi
I have recently updated my Gear S3 Frontier to Tizen 3.0.0.2
On Tizen 3.0.0.1, I had a battery life of approx 3 days - after updating to Tizen 3.0.0.2, I have a battery life of max 1,5 day.
1. Do other users experience the same?
2. Does anyone have an idea of what could suddenly drain my battery so quickly?
Solved! Go to Solution.
03-12-2018 08:13 PM - last edited 03-12-2018 08:15 PM ) in
WearablesScampatrol
Gear s3 gear frontier
Iphone 5
tizen 3.0.0.2
software R760XXU2CRK2
knox 2.2.0
04-12-2018 12:43 AM in
WearablesI ll get a new watch tomorrow what do you suggest? Should I delete the app on my phone ? Will it work if I keep the watch in older version?
04-12-2018 07:13 PM in
Wearablesdidn't do the job for me....still having huge draining problem...seems that settigs app and then notification drain the most power
05-12-2018 07:27 PM in
WearablesI'm to the point that I just don't get this watch. Had battery problems last week, reset, worked fine until 2 nights ago. Then I went to bed with 80% power and by 3am it died. Recharged it at 6am yesterday and it's only used 30% of it's power 36 hours later. It's on course to last 3 days, which it has never done.
Only comment I can make is...WTF!?
06-12-2018 09:38 PM in
WearablesHello,
I'm getting sick of it!! I spend £300 to get a bloody thing. Had an issue for a while before last software update and I hope that the problem will be solved. It looks good for a fist few days and then get back to the situation befor an update.
I will try to give it back as I'm very dsapointed.
08-12-2018 08:43 AM in
Wearables08-12-2018 09:56 PM in
WearablesInstall plugin 2.2.03.18101561 from mirror site and problem is solved. Back to 2-3 days of battery life.
08-12-2018 10:10 PM in
Wearables
@decoo wrote:Install plugin 2.2.03.18101561 from mirror site and problem is solved. Back to 2-3 days of battery life.
Can you provide a link to that file?
08-12-2018 10:18 PM in
Wearables08-12-2018 10:19 PM in
Wearables
