28-05-2018 03:58 PM in
WearablesHi
I have recently updated my Gear S3 Frontier to Tizen 3.0.0.2
On Tizen 3.0.0.1, I had a battery life of approx 3 days - after updating to Tizen 3.0.0.2, I have a battery life of max 1,5 day.
1. Do other users experience the same?
2. Does anyone have an idea of what could suddenly drain my battery so quickly?
Solved! Go to Solution.
21-10-2018 01:47 PM in
Wearables21-10-2018 02:36 PM in
Wearables
@catsuk wrote:
@majornerd wrote:try the following:
I had the same issue and found the solution on another forum that has worked like a charm, Charged to 100% yesterday 9am 10/18 and at 2:10 pm est today I still have 53% left and that is with location turned on and heavy interaction thru the day.
1) go to settings on watch and go to "about gear" Scroll down to "report diagnostic ancd usage information and uncheck it.
2) next, and I thought this was a funny solution, but after the above put your watch on the charger and while it is charging, press and hold power until it reboots and let it finish charging.
3) welcome to 3 days of battery life again.
Followed above yesterday ..after 10 hours over night now on 89 % . Are you some kind of Samsung Shaman ?.
thanks
Update... 1 day and 14 hours still on 63% ... just turned off "Report Diagnostic and usage info " and the reboot on the charger. looking good.
21-10-2018 08:56 PM - last edited 21-10-2018 09:23 PM ) in
WearablesThanks. I've found something else that works for me last night at
https://www.iotgadgets.com/2018/10/samsung-gear-s3-and-gear-sport-battery-drain-problem-heres-a-fix/
But the way I see it, if passive usage data collection is causing this issue then it can get turned off anyway! So I followed your instructions.
Thanks to all who suggest turning off usage data collection and rebooting, it sounds like that's working as well.
24-10-2018 09:54 PM in
Wearables24-10-2018 10:12 PM in
WearablesHi mate go to phone settings go to apps then down to gear s plugin click on storage and clear data that will help you. A. Harvey
25-10-2018 09:12 AM - last edited 25-10-2018 09:16 AM ) in
Wearables
@CAZE wrote:
Hello I am experiencing serious issues with the battery life of my Gear S3 classic I already have installed all software updates to the versions shown below: Model SM-R770 Tizen 3.0.0.2 R770XXU2CRH1 KNOX 2.2.0 Fully charged it lasts only 4 hours until the watch shuts down. Then when I put it in the cradle to charge it again, it shows that the battery is still at 60-70%. From then, A full charge will take less than half hour until the green light on the cradle indicates that the charge is complete, even tough the battery is “supposedly” totally empty. Then the cycle repeats: battery will last only 4 hours , take it to the charge cradle, Watch shows the battery at 60%; charge in the cradle for 30 min or less…. All these means, that I have to charge my Gear twice a day. I have seen in various forums, that these issue is very common and so far no fix for it.
Hi @CAZE, please search for the TAG "Solution"... you need to disable in the smartwatch the report and use. This fixed it
It's in the sheet 15 of this thread
25-10-2018 12:21 PM in
WearablesNo need to do anything just go to play store App and give One star rating to Gear app,your problem will solve within a weak if they go through your comment.
30-10-2018 08:38 PM in
WearablesI just did.
More should as well.
05-11-2018 09:56 AM in
Wearables05-11-2018 09:58 AM in
Wearables
