28-05-2018 02:58 PM
Hi
I have recently updated my Gear S3 Frontier to Tizen 3.0.0.2
On Tizen 3.0.0.1, I had a battery life of approx 3 days - after updating to Tizen 3.0.0.2, I have a battery life of max 1,5 day.
1. Do other users experience the same?
2. Does anyone have an idea of what could suddenly drain my battery so quickly?
Solved! Go to Solution.
19-10-2018 04:47 PM
I did a forced stop on it on the phone with no impact. Using Note5.
19-10-2018 04:50 PM
19-10-2018 07:14 PM
I had the same issue and found the solution on another forum that has worked like a charm, Charged to 100% yesterday 9am 10/18 and at 2:10 pm est today I still have 53% left.
1) go to settings on watch and go to "about gear" Scroll down to "report diagnostic ancd usage information and uncheck it.
2) next, and I thought this was a funny solution, but after the above put your watch on the charger and while it is charging, press and hold power until it reboots and let it finish charging.
3) welcome to 3 days of battery life again.
19-10-2018 07:18 PM - last edited 19-10-2018 07:30 PM
try the following:
I had the same issue and found the solution on another forum that has worked like a charm, Charged to 100% yesterday 9am 10/18 and at 2:10 pm est today I still have 53% left and that is with location turned on and heavy interaction thru the day.
20-10-2018 06:01 AM
I also disabled diagnostic reporting and health notifications and after almost 24 hours I still have 75% battery. Not sure which one of the two worked though.
20-10-2018 08:03 AM
Tried this and it seems alot better hopefully tjis will keep it going until samsung get their act together and put out a new firmware
20-10-2018 08:10 AM
It seems battery life is back to normal. Does it make sense to replace my gear S3 since I have only few hours left for the replacement window.
20-10-2018 08:13 AM
It worked!!!
Just follow the instructions from majornerd.
I just enable the auto detect workout and didn't drain my battery
20-10-2018 09:55 AM
I know it's annoying, the main reason why i changed from Apple over to Samsung. Big retailers do this, there was s post mistakenly made live by Apple saying they on purpose produce updates to defect the current models to force people to upgrade on new releases. Apple apologuesd so guessing Samsung doing the same. This is why i was hesitate to get a smart watch the hassles we all go for and you think normal watch be better off then smart watch.
20-10-2018 10:27 AM
@majornerd wrote:try the following:
Followed above yesterday ..after 10 hours over night now on 89 % . Are you some kind of Samsung Shaman ?.
thanks
