12-10-2019 02:29 PM - last edited 16-10-2019 11:11 AM by AntS ) in
Hello, I have S3 Frontier and I would ask if It be possible increase the time notification sound volume.
Solved! Go to Solution.
12-10-2019 06:31 PM
From Settings / Sound & Vibration /Volume / Notifications / set 10 max
It is the only method to change volumen notification saved. For to change an expecific ring or note you will need to change default files
12-10-2019 06:31 PM
12-10-2019 06:32 PM
Hi and you are welcome
See you on Forum
21-10-2019 09:12 AM
Thanks for yours kindly replies. Where I can find default files about ring or note?
