Gear s3 batery draining
(Topic created on: 26-12-2018 08:29 PM)
Jammybo1802
My gear s3 frontier after being fully charged will flash battery low after about 30 minutes but when I put it back onto charger it will show battery 80% any ideas have done full factory reset etc etc etc but to no avail. Any ideas welcome. Thanks
4 REPLIES 4
BandOfBrothers
Samsung Members Star ★★
Usually a reset of the watch within its settings helps with such issues.
As this hasn't then I'd suggest to visit a Samsung Experience Store or Samsung Service Centre so they can run a diagnostic test.
Daily Driver > Samsung Galaxy s²⁴ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
Jammybo1802
Ok got phone sent away to samsung replaced battery and mother board got it back it needed updated but read in the forum a couple of people updated then battery started to drain again. So set to manual battery lasts about 4 days before needing a charge but the big question is do i update the software.
BandOfBrothers
What does the update contain is the bigger question @Jammybo1802
Security Patches can be downloaded separately away from software update via your phones menu system.
Ultimately updating is going to be your informed decision.
Jammybo1802
Not sure think it said battery fix but don't really know. Not sure how to find out without downloading it.
