How can I get a new genuine strap?
They suggest to buy watchbands from Amazon.
"The size of the band is available in 2 sizes, small and large. To view the wrist measurement guide, click here. You can purchase replacement bands from retailers such as Amazon"
Current Phone ~
Samsung Note 20 Ultra 5G SM-N9860_256Gb SnapDragon 865+
Samsung One Ui 2.5/ Android 10.
Sorry i am a bit late on this one but I must admit I did like the way the fit is designed.
But for me i am heavy handed and that little push in wouldn't have lasted long
There are many other straps available but I bought tg greatfine silicon stap that the gear just slots as it's silicon and as raised edges protecting it from most knocks and as a result 6 months later my gear is still looking brand new
If you're looking for genuine straps, try here:
https://rounded.com/gear-fit-2-sm-r360/
You can buy just the one side you need. I bought one side due to the clasp coming out about 18 months after I got the GF2, then I bought the other side after that one failed. The glue holding it in just seems to fail. 18 months after getting the first half of the band, that same side failed again.
Good to have the option of a genuine Samsung Strap.
But a tad expensive at approx £45 for both sides of strap and cheapest shipping from Netherlands to UK
