Gear Fit 2 Pro completely unresponsive.
(Topic created on: 13-12-2018 07:41 PM)
MattGough
My Gear Fit 2 Pro has completely died.
It was fine earlier today, but went to simply check the time and nothing.
Haven't been able to turn it on since, and it won't charge.
It's only around 6 months old, maybe a few more.
Any suggestions?
1 REPLY 1
AndrewL
@MattGough: If you have connected the device to your charger and it is still unresponsive then please visit a Samsung Support Centre to where an engineer will be able to carry out a warranty inspection. To find your nearest one please check the following link, select 'Mobile Device > Phones, Tablets and Wearables' and enter your post code: http://www.samsung.com/uk/support/servicelocation/
