Gear Fit 2 Pro Bluetooth Failure with Pixel 2 XL
(Topic created on: 26-02-2018 01:58 PM)
Anonymous User
Not applicable
No way to connect via BT my Gear Fit2 Pro to Pixel 2 XL smartphone.
I tried to remove the BT connection and start again the procedure (indicating the couplig number on both devices, therefore the connection is working for a while), again and again.
No connection available.
5 REPLIES 5
melorib
Mine has been connecting properly since February, but yesterday it disconnected.
Sometimes I manage to pair, but it disconnectes quickly, never was able to connect Samsung Gear again.
Please help, Samsung just tells me the normal procedure, nothing new...
Anonymous User
Not applicable
Try to remove and reinstall samsung app.
In most cases it works.
Unfortunatly Google Pixel 2 is not Samsung "friend" o viceversa? No way to solve problems with samsung support.
Second option: change the Gear as I'm doing.
melorib
I did that so many times already...
What are you getting, I only need a good amoled screen to be able to read notifications, and waterproof.
Anonymous User
Not applicable
I'll try the new Xiaomi Mi Band 3. Probably not comparable (the price is 1/5) but just to see how much Pixel Friend is.
melorib
I tried with 2 different phones and they dont see the band either, so it is Bluetooth not working, anything I can do ? I bought it from Amazon...
