Galaxy watch active 2 - battery issue
(Topic created on: 05-05-2021 11:04 AM)
Emiliano26
After the yesterdady software update on the active 2 I noticed the battery draining very fast!! Usually a full charge last for 2 days.
This morning when I turned on the watch the battery went from 93% to 0 in just 3 hours.
Anyone else had the same problem??
6 REPLIES 6
Fiona26
Samsung Members Star ★★
Mine seems to be OK so far. Took of charge around 5 this morning and sitting with 87%.
Emiliano26
That's strange....don't know. Now is on charge, waiting to be full then I'll see how the battery will last. Hopefully will start to work properly
Fiona26
Press the power button hold it in until it reboots. See if that helps after you have fully charged it.
Emiliano26
Thanks for the advice. I rebooted the watch... let's see how long it will last 🤷🏻 🤞🏻
JohnT1974
Had exactly the same problem. My galaxy active 2 went from 100% to 40% in 3-4 hours. Deleted apps, done a backup and reset and battery usage shows no obvious candidates - all showing 1% usage. Must be the update
Emiliano26
Once the battery died I charged again and after turning on I rebooted the watch. Hopefully since than I didn't have any more problem with battery drainage
